6
This discussion topic has been answered Discussion topic: Booster & Mini Box won't connect.
This message was authored by: Chanty25
Sky router and TV is all good, three green lights on the router. Booster (white one) only has two lights. The middle light is out. So Sky Q Mini box won't connect. We had a power cut today but Mini box was off at the time. Any help greatly appreciated. Thanks.
Avatar for Chanty25
This message was authored by: Chanty25 Answer
Re: Booster & Mini Box won't connect.
Thanks for your help. I think its knackered. So I presume ill need an engineer out or can I just order a replacement.
Avatar for Chanty25
I have done all the help steps online....... twice. 🤔
@Chanty25 reboot the booster and redo the connection to the hub using the steps here https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
If it still,doesnt connect move it closer to the hub however it is possible the unit was damaged by the power cut so msy need replacing which Sky will do if they supplied the unit to you.
Avatar for Chanty25
@Chanty25 You should try the just order a replacement and see how it goes, there are two versions off the Sky Broadband Booster version so double check which model you have if even that type?
This message was authored by: Rachel257
My sky Q mini box wont work
@Rachel257 Are you thinking that you have a network problem with it then?
