Discussion topic: Booster 4
Message posted on 22 Aug 2025 11:20 AM
Booster 4
I have received a box and letter to retirn a booster 4 ( sky Broadband Hub ) by the 5/10/2025 . I have not canx my broadband ? I have had fibre installed by yourself which you recommended which plugs into the sky broadband Hub. I have not been given any new equipment with this so I am unsure as to why or what I should be returning.
kind regards
Message posted on 22 Aug 2025 12:45 PM
Re: Booster 4
If you previously had a booster on loan under the Broadband Boost subscription supplement but have now moved to a white Max Hub then it's no longer appropriate hardware.
Message posted on 22 Aug 2025 12:57 PM
Re: Booster 4
@Toria31 See the link below it will show you the Sky Broadband Booster picture!. Models are SE210 or the SE210a!
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
Message posted on 26 Aug 2025 10:40 AM
Re: Booster 4
- I dont have any of the boosters in the image ?
I have had fibre put in and the box on the wall goes into another box which is the router . I have not has booster box dor over a year as this was returned when I had a sky engineer man round last time .
Message posted on 26 Aug 2025 10:46 AM - last edited: 26 Aug 2025 10:46 AM
Re: Booster 4
@Toria31 Then sky have NO record of you returning the item, and they are now saying do it or pay the charge for keeping it!
Message posted on 26 Aug 2025 11:46 AM
Re: Booster 4
Can you please call me to sort this situation out as i dont own a booster box
Message posted on 26 Aug 2025 11:48 AM - last edited: 26 Aug 2025 11:50 AM
Re: Booster 4
Message posted on 26 Aug 2025 11:56 AM
Re: Booster 4
I dont have a white hub box ? I still have the old back hub . Should I have been given a new box when they put in fibre ? I only was sent a new lead ?
Message posted on 26 Aug 2025 11:57 AM
Re: Booster 4
@Toria31 NO!
Message posted on 26 Aug 2025 12:41 PM
Re: Booster 4
Please ignore me I have dound the equipment you're on about. Thank you for your help .
this will be posted out to you today
Message posted on 26 Aug 2025 12:46 PM
Re: Booster 4
@Toria31 KEEP the postal receipt that you get from your postmaster FOR EVER, that is the proof you have sent it back, and include a copy off your request paper work, and take a photo off the unit label on the back for the serial number!
