Discussion topic: Block a device
This message was authored by: Mr.+Li
Block a device
How can I block a device in my home broadband WiFi?
Re: Block a device
@Mr.+Li What is it that you are specifically trying to do, and which sky hub do you have? Look at the sky max help!
Sky WiFi Max | Sky Help | Sky.com | Sky Help | Sky.com
Avatar for Mr.+Li
Re: Block a device
My model is SR203, only find the deives list in service checker. But can't block one of them.
Re: Block a device
@Mr.+Li You cannot with the SR203 sky Hub, the controls are not there for that specific hub, what is it that you are trying to do?
Avatar for Mr.+Li
Re: Block a device
That means I can't do that
Re: Block a device
@Mr.+Li You are correct, if you want to use parental controls to block a device off the internet then you have to get the sky Max hub with the max addon package for it all, it is linked above for you!
