This discussion topic has been answered Discussion topic: Black cable required
Message posted on 26 Mar 2025 09:38 AM
Message posted on 26 Mar 2025 10:18 AM
Very unclear what you mean. Are you saying you expected to get an FTTP installation and got FTTC instead? Is FTTP actually available in the area?
Message posted on 26 Mar 2025 10:21 AM
Re: Black cable required
Yes the engineer who attended said that the engineer used equipment already in situ and I don't had digital. No ADSL black cable connection.
Message posted on 26 Mar 2025 10:35 AM - last edited: 26 Mar 2025 10:36 AM
ADSL is obsolete, and still in use in only a tiny percentage of addresses.
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
Message posted on 26 Mar 2025 10:38 AM
@Sandy_G there are two main types of broadband delivery full fibre where a ONT box is fitted and partial fibre where the hub connects to the standard phone socket. Which you get depends on what services Openreach can offer in your road. Sounds like you have a partial fibre service. This used to use ADSL but these days the vast majority of services use the faster VDSL system speed you get depends on the length of the copper phoone line..
The longterm plan is for all lines to be switched to full fibre and Openreach are investing £20bn to transfer those lines which meet their commercial criteria you can check what their plans are for your address here https://www.openreach.com/fibre-checker full fibre supports faster speeds and is far more reliable. Something around 75% of UK addresses can already access full fibre from at least one provider this is expected to rise to 96% by 2027.
