Discussion topic: Bedroom dead zone and WiFi dropping
This message was authored by: 99Nico
Hi,
So recently got connected to sky, full fibre package at ~900Mbps
Hub is the white Sky Max hub I believe, speeds to the hub are ~900Mbps, wireless speeds in the same room as the hub are fine at ~600-800Mbps.
The issue is everywhere else.
Upstairs bedroom furthest away from the hub barely gets 25Mbps which is not ideal when hoping for the 600 minimum. WiFi will also frequently drop and devices will disconnect continuously.
Ethernet isn't necessarily an option due to location of the bedroom in comparison to the hub location.
Hoping to be put in contact with someone who can point me in the right direction.
thanks
Re: Bedroom dead zone and WiFi dropping
@99Nico The information that you need, just make sure you are paying for the addon subscription.
getting sky max and how to get the pod's
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
Avatar for 99Nico
Cheers mate, will give it a look over
