Discussion topic: Bb issue
Message posted on 17 Sep 2025 12:10 PM
Bb issue
Is there broadband outage midvile Middlesbrough?
Message posted on 17 Sep 2025 12:32 PM
Re: Bb issue
@Steve540
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
