Discussion topic: Bad wifi
Message posted on 22 Dec 2025 12:03 PM
Bad wifi
The WiFi in my house is really bad
Message posted on 22 Dec 2025 12:21 PM
Re: Bad wifi
@Jeannette6 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
