Discussion topic: Bad connectivity
This message was authored by: Roboman1984
Message posted on 23 May 2025 12:17 PM
Bad connectivity
On Fibre broadband. Sky q box hard wired in to the router.
Sky mini box keeps dropping out from router and has an unstable connection even though it is in the same room as the router.
Message posted on 23 May 2025 12:53 PM
Re: Bad connectivity
@Roboman1984 Mini relies on the Main Q sat box.
Find out more
Message posted on 23 May 2025 02:32 PM
Hi @Roboman1984
If your Q mini s far from the main Q box you'd need a Q booster inbetween as the router can't serve it for all of the required connections.
I am NOT a Sky Employee
