Discussion topic: BB slow
This message was authored by: Ruksar1
BB slow
Since my gigafast has been installed after 2 days the wifi is slow even slower then the 100mbps Internet package I had before and now I have 900mbps but doesn't feel fast like it did first 2 days of when it was installed
This message was authored by: Me134
Re: BB slow
Firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
