Discussion topic: BB not working
Message posted on 22 Nov 2025 11:34 AM
BB not working
light flashing green on router
Message posted on 22 Nov 2025 11:41 AM
Re: BB not working
@Nelmesee
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Message posted on 22 Nov 2025 11:47 AM
Re: BB not working
Hi a can't connect my tv to my broadband as it's saying thereis no signal as they chanced it to fiber broadband it was ok before they touched it it now saying there is no signal until u go near it
Message posted on 22 Nov 2025 11:53 AM
Re: BB not working
@Sean176 Same hub, same TV, same place for the hub as before the Fibre install?
