Discussion topic: BB always droppingout
This message was authored by: po4melt
Can someone please contact me please about the BB at Garrod Approach. There is hardly a day goes by without it dropping out and a number of times when it does.  We lose WiFi, sky tv eg sport. This has been going on now since early Jan at least . Thankyou
Re: BB always droppingout
@po4melt
Sky won't / can't contact you based on your post. Your Community username isn't linked to any Sky accounts you may have, so no one knows who you are anyway.
