Discussion topic: Asus Mesh Direct Connection setting for Gigafast plus
This message was authored by: Shadowman007
Message posted on 24 Jan 2026 11:48 AM
Hi, please if anyone can guide me would appreciate it. I currently have Gigafast plus 5Gbps and want to use my Asus Mesh router which is the Asus Zenwifi BQ16 is there any settings I need to put in the Asus router? or is it just plug it in that's it? I seen some settings online that's why am confused a bit like DHCP Option 61 ?
Message posted on 24 Jan 2026 12:28 PM
Re: Asus Mesh Direct Connection setting for Gigafast plus
@Shadowman007 Just plug it in and let Asus work it all out if it can, if not then that's the time to go look, you can search XT8 and somewhere around July you will see a few images posted up that will help!
