Discussion topic: Wfi max
Message posted on 24 Jan 2026 01:50 AM
Wfi max
Wanting to.prder wifi max hub for the fttp 500 broadband but for some reason im stuck with bb boost and will not let me change over to the wifi max hub.. is there a reason for this
Message posted on 24 Jan 2026 08:05 AM
Re: Wfi max
@Aleeyah You may have to call sky to do a sky Max upgrade and the addon package if that is what you need, going from a sky Broadband Hub if that is what you have currently, expect to have the £10pcm applied to your package and if sky do allow you to do the change etc!
getting sky max and how to get the pod's
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
Message posted on 24 Jan 2026 12:05 PM
Re: Wfi max
Thanks , ive called sky numerous times to change over to wifi max hub and they cant do it. Ive to stick with boost. I think there is something wrong with the account.
Message posted on 24 Jan 2026 12:13 PM
Re: Wfi max
@Aleeyah You did see this or did you just skip or not even read it!!
"""Sky WiFi Max isn’t available to everyone just yet. Can't get it yet? Watch this space or check out Sky Broadband Boost instead."""
Message posted on 27 Jan 2026 10:40 PM
Re: Wfi max
- Thanks for your help 👍
