Discussion topic: Artificial Intelligence
This message was authored by: Gaz80
How can we eliminate AI from Sky😖
Re: Artificial Intelligence
@Gaz80 short answer you can't. The online assistant uses AI as does yhe phone IVR system etc
@Gaz80
You may be confusing Sky Group with Skynet*, in which case the traditional approach is some complicated shenanigans involving time-travel ; )
* a tradename registered to the Cyberdyne Systems Corporation rather than Comcast.
