Discussion topic: Apps unable to start and constant buffering
Message posted on 30 Nov 2024 06:08 PM
Streaming apps are failing to start and even NOW tv continually fades out and goes bleary, tothe point were you are unable to watch.
Message posted on 30 Nov 2024 06:15 PM
Re: Apps unable to start and constant buffering
@Shukes1 sounds like poor network connection tonwhatever device you are using to stream.Runnthe networkntest in the Get Help menu in the Netfix app to see the speed you need over 25Mb/s for UHD around half that for HD. The Service Checker in tgecMy Sky app will tell you the speed to the hub if tgat us fine you need a better connection to your device, ideally you would want to use Ethernet if WiFi is poor. Other options are powerline networking kit thst uses the mains wiring or getting better WiFi kit.
