4
This discussion topic has been answered Discussion topic: Applied for Gigafast
This message was authored by: Tas70
Hello. I chosen Gigafast package. does anyone know if Sky will send me faster router. thanks
This message was authored by: stereohaven Answer
Re: Applied for Gigafast
If you have the City Fibre network in your area and have ordered either:
  • Full Fibre 2.5 Gigafast+ (2500Mb/s)
  • Full Fibre 5 Gigafast+ (5000Mb/s)
Then you will get the new WiFi 7 Gigafast hub.
Anything else will get you the white, rectangular WiFi 6 Sky Max Hub.
See here: https://helpforum.sky.com/t5/Broadband-Talk/Introducing-Gigafast/ba-p/5032203
Avatar for Tas70
thank you
This message was authored by: peter-marlow+1966
I got the wifi max hub when I upgraded  to gigafast broadband in January last year
P c marlow
Unless you are a current Sky Broadband customer with a Sky Broadband Hub and don't opt to add the WiFi Max subscription supplement.
