Discussion topic: Any update on vo-WiFi not working on Sky max routers
This message was authored by: johnthecyclist
Hello, is there any update on vo-WiFi not working on Sky max routers. Most frustrating!
Thanks, John
Re: Any update on vo-WiFi not working on Sky max routers
Hi @johnthecyclist
I am not aware of a general fault on Voice over WiFi. What device & network is it not working on?
I am NOT a Sky Employee
Avatar for johnthecyclist
OnePlus 12 on Id mobile, and a Pixel 6a on Smarty. Neither can use vo-WiFi via the router.
@johnthecyclist
Have you contacted your mobile phone providers and asked them if its all okay on their side?
WiFi calling on the Sky Max hub was fixed a long time ago so either your hub is on a really old firmware version or there is something up with your sims.
Hi, thanks for everyone's replies. Our vo-WiFi is now working, so I don't know if the router has had an update or the reboot has sorted it. But we did not have any vo-WiFi for a couple of days, strange!
