Discussion topic: Android phone WiFi keeps dropping out
This message was authored by: red+rover
I have recently changed routers and have a white router which is supposed bang up to date.
The problem I have is my Sumsung S24 android phone keeps dropping out when at home. I have the security setting at there lowest and still it keeps dropping out.
I have tried all the setting on the phone to no avail.
Can somebody help me please
Re: Android phone WiFi keeps dropping out
@red+rover First thing to do, turn off mobile data on the phone, then see if it stays up and connected to the wireless wi-fi connection when you are at home! Will indicate wi-fi bars with a 6 in them while connected, if the ! mark appears then wireless connected no internet.
Have you adjusted any off the settings on the Sky Max hub that you have!
Avatar for red+rover
Level 3 icon
Thanks JimM1 it seems that your fix is working👍
@red+rover Just the heads up it's not a fix as such, you phone is chasing the strongest signal between wireless wi-fi and 4g/5g mobile network, turning the mobile off just keeps it latched on your wireless wi-fi signal at home which thankfully appears to be adequate to keep you up and connected!
I am fortunate having a very poor mobile signal I have to rely on wi-fi calling NO choice lucky me!
