Discussion topic: Amber light on wifi
This message was authored by: WiFiissues
Amber light on wifi
No internet connection
Re: Amber light on wifi
@WiFiissues
It could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back up and running by the morning use the below link to check to see if there are any problems or outages nearby
