Discussion topic: Amber light on booster
Message posted on 05 Dec 2025 09:23 AM
My booster has an amber light and won't connect. Viewing similar issues on this forum suggest this is due to the booster situated too far from the hub. But, it's worked up until now and nothing has moved. Plus, it was installed this way by the engineer and tested.
Message posted on 05 Dec 2025 09:29 AM
Re: Amber light on booster
@KateM30 How do you know that it is not working? Take it closer to the sky Hub, plug it in and let it power up, if it goes to 3 green lights then it's a distance issue, if it stay's as it is then possibly it's just not working correct! Link below for the booster setup and repairing the two devices if needed.
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
