Discussion topic: Amazon fire stick
This message was authored by: Anthem1
Amazon fire stick
My Amazon fire stick is not showing on my device list , it was however now it ain't?
I unplugged it for 2 hours whilst out powered back up once in and still the same it keeps buffering and is not on my device list to prioritise via WiFi.
i use it for Amazon prime , Netflix  as they buffer on my Sky'Q box.
Re: Amazon fire stick
@Anthem1 the device list often omits a few devices which isnt an issue assuming they are connected and working. Sounds like your Sky Q box has insufficent WiFi signal you coukd ask Sky to investigate as they still send eniginerrs out to look at Sky Q issues.
This message was authored by: Me134
Make sure that the stick is on an HDMI extender lead rather than buried behind the TV. They have tiny antennas that function far better if they have line of sight of the router. Doesn't do any harm as regards the heat either.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
