Discussion topic: Amazon Smart Plugs/Ring Doorbell
Message posted on 23 Feb 2025 07:18 PM
Following install of a Sky WiFi Max hub my 4 Amazon Smart Plugs and Ring door bell have failed to reconnect to it? I have attempted to restart the plugs. They fail to do so. The Ring Doorbell also fails to reconnect. Numerous attempts by adding password have failed. Shall I reconnect the old router to see if I get the same response? Also the network connection to my laptop is unstable? Any help or responses much appreciated. Thank you....Clive
Message posted on 23 Feb 2025 09:22 PM
Re: Amazon Smart Plugs/Ring Doorbell
@Teleprinter+Op wrote:Following install of a Sky WiFi Max hub my 4 Amazon Smart Plugs and Ring door bell have failed to reconnect to it? I have attempted to restart the plugs. They fail to do so. The Ring Doorbell also fails to reconnect. Numerous attempts by adding password have failed. Shall I reconnect the old router to see if I get the same response? Also the network connection to my laptop is unstable? Any help or responses much appreciated. Thank you....Clive
One thing you could try lowering the WiFi security settings in the Mysky App.
Open the App and click Broadband >>> WiFi Settings >>> Advanced Settings >>> WiFi security level >>> change to WPA2
Sky Q 1TB UHD
LG TV
Sky Mobile
Message posted on 23 Feb 2025 09:41 PM
Thank you so much for your quick response and advice regarding the issues Im having with my secondary devices. Since posting this I have since discovered that the previous Sky Wi-Fi hub name and the previous password should be used despite the new Sky Wi-Fi Max Hub having its new and unique and different Wi-Fi name and password ? Thank you again so much
