Discussion topic: Cuts out several times a day
Message posted on 23 Feb 2025 01:59 PM
My connection cuts out several times everyday and it's getting tiresome. It's disrupting my son's gaming and us watching tv
Message posted on 23 Feb 2025 02:11 PM
Re: Cuts out several times a day
@Delta76
Message posted on 23 Feb 2025 02:51 PM
I have been having the same problem for about 6 months now. The router switches itself off 2 or 3 times a day. I can no longer work from home as I have no confidence it won't reset itself whilst I'm on a Teams call. Run the service checker multiple times and it says everything is ok. Tried ringing but I get a bot who tells me everything is Ok and then hangs up. How do I get through to a human
Message posted on 23 Feb 2025 03:02 PM
@Michael180
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
Message posted on 23 Feb 2025 03:05 PM
If you are on fttp, make sure you have the right setup. the Ethernet cable from the ONT (openreach box) need to be in WAN Port 4 on the back of the hub.
Try to switch off the hub for 15 minutes and switch it on again!
Message posted on 23 Feb 2025 03:20 PM
Right haven't been able to speak to anyone either. It's frustrating. Hope you get it sorted
Message posted on 23 Feb 2025 03:21 PM
Thank you @Michael180
Message posted on 23 Feb 2025 09:39 PM
What number are you using?
