Discussion topic: Alexa devices cannot connect
This message was authored by: Dave544
My amazon alexa devices and phones connect to the WiFi but don't work and there is no unter etc even though it shows they are connected
Re: Alexa devices cannot connect
@Dave544 do any devices work or is everything similarly affected? If so checkmthe lights on the Sky hub see https://www.sky.com/help/articles/hub-lights-explained-start
One tip from Sky if the lights on the hub say it is connected but nondata flows power down the hub for 60 minutes as that should sort the issue.
If the issue is on some devices but nit others it is most likely to be an addressing issue postcagain if that applies.
