Discussion topic: AgainNo wifi
This message was authored by: twist760
AgainNo wifi
yet again the wifi is not working
Re: AgainNo wifi
@twist760
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
