Discussion topic: Adjust Router to dual band
This message was authored by Trevor007 This message was authored by: Trevor007
Hi - I have just updated my router to a Sky 5ghz - my Sonos Beam only works on 2.4 ghz - can my router be adjusted to dual band ?
Re: Adjust Router to dual band
@Trevor007
To seperate the wifi bands to create two seperate ssids so the sonos can see the 2.4ghz wifi as seperate
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
@Trevor007
The Q Hub, Sky Broadband Hub and Max Hub are dual-band by default: as @cookiemonsteruk indicates, they broadcast 2.4Ghz and 5Ghz with the same SSID (network name) unless these are manually separated (which is not possible with the Max Hub).
The legacy Sky Hub (still in support but effectively obsolete) is 2.4Ghz only.
This message was authored by StuXxxxx This message was authored by: StuXxxxx
Often in these situations the answer is to temporarily disable 5GHz, establish the connection you require on 2.4GHz and then re-enable the 5GHz.  It’s usually establishing the initial connection that is the issue.
