11
This discussion topic has been answered Discussion topic: Account update to sky WiFi Max
This message was authored by: Agarici
Good afternoon, After a few weeks with very slow Internet connection and troubleshooting, I have had change my old Sky Q Hub with Sky Wifi Max Hub, but seems to be even worse. I'm on the fastest contract for my area. Do they need to update the system as my account still showing as using Sky Q Hub?! Thank you in advance Alex
Re: Account update to sky WiFi Max
@Agarici the old Sky Q bousters are not compatable with the new hubs so should be disconnected unless it is required to boost the signal from a Sky Q box to to Sky Q minis. If you have bought Sky WiFi Max then call Sky and request a matched pod extender - the package can supply up to 3 pods but the second and third are only supplied after an engineer visits.
You dont mention if you have Sky Q tv boxes but if you have these no longer act as wifi hotspots for your other devices.
@Agarici  Are you talking about the Wi-Fi around the property or in your overall broadband connection with the speed you are getting?
Avatar for Agarici
Im talking about overall connection. All my devices are wireless connection.
@Agarici
The issue likely isnt the router but either your line or local WiFi conditions. What service are you on currently? FTTC or FTTP?
I am NOT a Sky Employee
Avatar for Agarici
FTTC up to 74MB/s
@Agarici  Black or white router from Sky?
Avatar for Agarici
I change the old black with new white.
@Agarici  Do you have any booster pods in the property to help with your Wi-Fi coverage in the property?
Avatar for Agarici
I leave in a flat, hub is at the entrance, and have a booster in living room to cover the rest.
@Agarici  When you changed from the older router did you also change to the new booster pod?
Avatar for Agarici
I still use the sky q booster, don't have the newest version.
