Discussion topic: Accessing zoom
This message was authored by: kendee
Accessing zoom
Since moving to sky 2 weeks ago my wife has not been able to use zoom on her laptop over wifi. Her laptop does not have an ethernet port. What could be causing this. She is right beside the router and speed checks show good speeds
Re: Accessing zoom
@kendee Logon to your account, go to your products section and check where the Broadband shield is at, adjust and wait a few hours before checking zoom again, sky say a few hours i always say at least 24hrs but depends!
Sky Broadband Shield | Sky Help | Sky.com | Sky Help | Sky.com
Avatar for kendee
Re: Accessing zoom
Thanks, but every time I try to get into the broadband shield an error message comes up "sorry something went wrong, please try again later"
Re: Accessing zoom
@kendee Then you have an account issue, call sky dial 150 from your landline, and have the CS agent set it for you, would suggest you just do disabled on it!
Shield adjustment is fine, just logged into my account, went to products selected my BB, scrolled down clicked on the BB shield and all the settings popped up for adjusting!
Avatar for kendee
Re: Accessing zoom
I spoke with sky today. I went through the whole thing again and asked them to disable the broadband shield for me as I can't access it myself. I was told they could not do this, that I should show them a picture of the error message coming up when trying to use zoom and that the problem lies with zoom, not with sky.
We had no such issues with virgin media. So frustrating as my wife uses zoom a lot for work and what should be a simple fix has been made into a big issue
Re: Accessing zoom
@kendee How and by what device are you trying to get to your sky account, i just checked again using my laptop, sky.com logged in, selected my products, dropped into broadband devices as i have that and mobile, got an error could not show me all, who cares, down the page selected BB Shield and all open to adjust to whatever i want!
Avatar for kendee
Re: Accessing zoom
I have no luck on either mobile or laptop. I'm in Ireland, maybe it's different settings here
Re: Accessing zoom
@kendee Are you ROI side off Ireland, that may be possible question was asked before but the OP never got back as to what did or did not work?
