Discussion topic: Absolute joke
This message was authored by: Mrfedup1
Absolute joke
This company is a joke, no Internet and the booster is **bleep**
Re: Absolute joke
@Mrfedup1
You're only telling customers here.
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Avatar for Mrfedup1
Re: Absolute joke
Yeah I know I'm just letting people know how rubbish Sky is , I'm an expert on fault finding now,since day one it's only ever worked intermittently, works stops works stops works stops, a number of times saying there's a line fault then works stops works stops , totally stopped working now 4 days,engineer coming tomorrow,I get better signal from my roaming on my mobile,I've even had second generation sky glass, it's a joke
Re: Absolute joke
If there's an external line fault then yes, that would be the case.
Any other ISP using the same circuit would experience the same problem: that's inherent to the nature of a cabled connection.
