Discussion topic: ASUS Router amber LED
This message was authored by: Baldie101
anyone know what my issue is please? I have had an ASUS Zen WiFi Aimesh AC3000 setup for for 3 years. Originally with BT and all worked great. Switched to Sky last year and eventually got it working but the LED's on both the hub and node only display amber. I no longer have solid white. I believe this indicates that the signal is weak on the node but why would the hub be showing as weak too?
Re: ASUS Router amber LED
@Baldie101 first step would seem to be logging into the router's interface as that should tell you if there is.an issue.
This message was authored by: cuke
Avatar for Baldie101
Really?? Ok! Thanks for that
