7
This discussion topic has been answered Discussion topic: ASUS DSL-AX82U with Ultra Fast 1
This message was authored by: Lootington
I was wondering if anyone could explain the settings for configuring the DSL-AX82U, I have Ultra Fast 1 provided by openreach (Socket 5C ) into the property. I have tried using the Automatic DSL configuration but it does not seem to detect anything. I have also tried configuring manually from what I could find on the forums but could not get the modem to successfully connect. If someone could look at the settings I have attached and tell me where I'm going wrong it would be greatly appreciated.
Screenshot_20240921_000403_Chrome.jpgScreenshot_20240921_000412_Chrome.jpgScreenshot_20240921_000432_Chrome.jpgScreenshot_20240921_000345_Chrome.jpg
This message was authored by: cookiemonsteruk Answer
Re: ASUS DSL-AX82U with Ultra Fast 1
@Lootington
Yes
@Lootington as far as I am aware the Asus DSL-AxX82U does not havea G.Fast modem so cannot be used on an Ultrafast1 service over copper. You would need to source a G.Fast modem or use your Asus behind the Sky Broadband Hub SR204 in a double NAT config.
Avatar for Lootington
@Chrisee Would a Draytek Vigor 166 be compatible?
@Lootington
Yes
@Lootington
Are you in the uk!
@cookiemonsteruk Yes I am
@Lootington
You would need to change connection type from ppp to auto ip this should bring up the client identifier (option 61) field where you enter
anything@skydsl|anything
Also if you don't enable vlan id/vid on your draytek at 101 then on the asus goto lan settings->iptv set vlan id/vid as a manual setting in internet at 101
@cookiemonsteruk Thank you so much for the guidance, really appreciate it.
