Discussion topic: A few devices not connecting to WiFi
This message was authored by: RamJen
All of my devices were successfully connected to the WiFi, but since lunchtime on Tuesday, 9th September, some of them have stopped connecting
Re: A few devices not connecting to WiFi
@RamJen
Try a reboot of your broadband hub at the mains.
Avatar for RamJen
Thank you for responding.
I have rebooted the WiFi again and still no change. The device is not connecting to the Ring doorbell and my WiFi extender which is connected to the hub via WAN/LAN port.
@RamJen Does your wifi extender work as a wired backhaul device, some do not, as for the Ring doorbell do you have a sufficient 2.4Ghz wireless wi-fi signal to reach it, easy check stand outside with the doorbell, if your mobile loses connection wi-fi is not reaching the area!
You do not say which sky Hub you have but the Port 4/wan is good as a Lan port as long as you are not on a FF connection will work fine as a Lan port, if you do go and set it as a WanoE then it can ONLY ever be a FF connection, all Lan functonality will cease as it wants Wan Connection Only!
