Discussion topic: 5 ghz
Message posted on 03 Jun 2026 10:50 PM
5 ghz
5 ghz not stable. In and out of service. Tv keeps telling me to reboot router.
Message posted on 04 Jun 2026 06:13 AM
Re: 5 ghz
@Joabengt wrote:5 ghz not stable. In and out of service. Tv keeps telling me to reboot router.
That suggests a weak wifi signal rather than a faulty router (although that is possible of course), first run a broadband check and make sure when it is finished to click through the wifi check as well.
The MySky app on your phone can also be used.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
Message posted on 04 Jun 2026 08:47 AM
Re: 5 ghz
Thanks, appreciated. I have a brand new LG smart tv. Not had any issues on 2,4ghz. The TV is only 2 feet away from new installed Router.
Message posted on 04 Jun 2026 08:55 AM
Re: 5 ghz
@Joabengt wrote:Thanks, appreciated. I have a brand new LG smart tv. Not had any issues on 2,4ghz. The TV is only 2 feet away from new installed Router.
Then if possible, set the TV up just to use 2.4Ghz via either it's own settings or (if possible depending on router) 'split' the 2.4Ghz & 5Ghz bands by renaming one (you can use the same password if needed) and connecting to the 2.4Ghz band. That said, if the router is that close, use an ethernet cable.
Not a Sky employee
