4
This discussion topic has been answered Discussion topic: 5 ghz Printers.
This message was authored by: Roger+and+out
5 ghz Printers.
I've recently changed my sky Wi-Fi  to a  FUll FIBRE-100 and a 5 GHz  hub, so my canon printer TS 8350  doesn't work ,unfortunately, won't connect to my phone or I pad.
So could anyone help with a good replacement printer using. 5ghz.
THANK YOU.
ROGER
Re: 5 ghz Printers.
@Roger+and+out
With a white Max Hub you may need to reduce the wireless security level from WPA3-T to WPA2-PSK using the Hub settings in the My Sky app.
Re: 5 ghz Printers.
@Roger+and+out
You dont need to replace the printer, just temporarily turn off the 5ghz WiFi in the router settings on the My Sky app
I am NOT a Sky Employee
Re: 5 ghz Printers.
@Roger+and+out
Avatar for Roger+and+out
Re: 5 ghz Printers.
I was going to do this but I was warned against it in the MY SKYAPP,when I tried it.!!!
Re: 5 ghz Printers.
@Roger+and+out
WPA2-PSK is still considered entirely adequate (except by Apple) and at the moment a significant percentage of wireless devices don't support WPA3 anyway.
