Discussion topic: 4 green lights no internet
Message posted on 13 Nov 2025 08:04 AM
As of 10pm last night my broadband dropped out.
The router showed 4 green lights at the time but I had no internet. I did a router reset all green lights came back on still no internet. I disconnected the router from the mains power for 1 minute reconnected 4 green lights still no internet. I have conducted the automated online service checker and it shows no issues, but there clearly is!
Divices connected with Ethernet cables show a connection but no internet access, devices connected by WiFi show WiFi connection but no internet access
Your assistance to resolve this issue will be greatly appreciated
many thanks
Ian Martin
Message posted on 13 Nov 2025 08:08 AM
Re: 4 green lights no internet
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
Message posted on 13 Nov 2025 08:15 AM
@Ian2058 there is a fault ygat turns up ever so often with these symptoms your hub is connected to a Sky server but no data passes. The nirmal solution is to piwer down the hub for y0 minutes which should connect you to a different node.
These servers handle over 5 million connections and occasionally a node goes faulty. The machines are placed in exchanges etc around the country so it takes time for a Sky enginerr to get to them
Message posted on 16 Nov 2025 09:21 PM
The issue could not be resolved locally by any of the above mentioned methods. However it was fixed by the sky network engineers remotely.
Thank you for your replys.
