19 Feb 2025 11:49 AM
Two questions for you guys
Can I use Ipvanish with the sky 900 service
Will my own router work in place of the suppled Sky router, I do have a connected BT ONT as well as my current Virgin 1 meg service
thanks in advance
john
14 Mar 2025 03:34 PM
Posted by a Superuser, not a Sky employee. Find out moreYes you can use any VPN provider with Sky and most 3rd party routers also work with Sky
14 Mar 2025 04:16 PM
Others have told me my TPLink Archer AX72 will not work with Sky ?
14 Mar 2025 04:21 PM
Posted by a Superuser, not a Sky employee. Find out moreTypically the requirement is that it supports DHCP Option 61, you would need to do your own research. Although if your on FTTP you can usually now get routers working by just enabling native IPv6
