21
This discussion topic has been answered Discussion topic: 3rd Party Router and Sky Q Mesh
This message was authored by: JackD1992
Hi, I am hoping someone will be able to advise me on best approach to upgrade my router to 3rd party. I am not a tech expert or IT specialist so looking for simple solutions that don't mess up my Sky TV or create a complex system for me to manage!
I'm a gamer and want to improve my WiFi set up for wireless streaming from PS5 to PS portal. My broadband speeds are decent and don't really impact remote play/streaming so much so that is not my concern, it's the poor performance of my current Sky router in combination with Sky mesh (x2 mini boxes) that worries me. I do not want to buy a good router and then it skew with my Sky set up.
My current set up works fine for our normal day to day stuff, but the router is not good enough for remote play/streaming gaming.
My current set up:
  • Black Sky hub router
  • Sky Q main box (wireless) in front room
  • x2 Sky Mini Box (wireless) in kitchen and upstairs in bedroom
  • Sky booster / extender upstairs (white) in upstairs office
  • Router split two channels: 2.4GHz and 5GHz, 5GHz used for remote play gaming for speed
  • PS5 wired via Ethernet to router using CAT8 cable.
I don't have access points in my walls so not in the market for pulling my house apart to Ethernet Sky mini boxes etc.
Is there a simple way I can get a gaming router to use on 5GHz channel for my gaming and then leave the current Sky router for our boxes on wireless? I don't want to introduce interference as that will make remote play even worse.
I have read that the new Sky Max router is decent and I don't mind upgrading / paying more for that but then I read you can't split the channels so that could be a pain. I need to keep 5GHz as free as possible for my gaming.
I appreciate any thoughts/advice in advance.
Jack
Standard black Sky hub router on superfast.
This message was authored by: jamesn123 Answer
Re: 3rd Party Router and Sky Q Mesh
@JackD1992
Your best option would be looking at a mesh solution like TP-Link Deco, Eero, Asus Ai Mesh or UniFi. Then deploy this with its own SSID & Password, leave the Sky network alone and just allow your Q boxes to use that.
I am NOT a Sky Employee
@JackD1992
Avatar for JackD1992
Thanks for the reply, James, your assistance is appreciated. I was looking at a Mesh system as they seem to be recommended as good options for remote play.
Would you suggest I just hardware a node to the sky router and then have a couple of nodes in other areas of the house as necessary? Would this not cause any interference with the Q mesh network for the mini boxes having two routers? Or is it unlikely?
@JackD1992
Yes that would be the best solution. It wouldnt cause interference as long as you set the mesh network to use different WiFi channels.
This message was authored by: LeoBlack30
I'm in the same position expect my Mini's are all hard wired.  Would I buy a mesh system,  plug it into the Sky Router,  and turn Wifi off on all the Sky devices?
Hi Leo,
So I can confirm that I went ahead and purchased a new TP Deco Mesh system and have hardwired that to my current Sky Hub. A few little issues at first getting set up but nothing too bad and now it is running sweet!
No major issues and connectivity is loads better than previously with just Sky router. I ended up upgrading my broadband for better uploads so that also helped. Basically I can play more portal anywhere in the house now, impressive.
I'd recommend taking a look at other posts on the forum as I am pretty sure you can connect your main Q box to a 3rd party router so if your mini boxes are wired then you can literally just get a mesh system and put your Sky router in AP mode. I couldn't do this because my mini boxes are wireless so had to keep Sky router on still.
Cheers
Jack
Thank Jack,  this is helpful.  I'll look up the AP mode thing now...
No worries. Not sure what your usage need is for but I keep my TP mesh just for the PS5 and portal so it's locked at 5Ghz with no loss of bandwidth to other devices in the house. Sky and TP mesh are completely separate networks. That could always be another option depending on your requirement.
The TP Deco units I have allow you to give priority of bandwidth to specific devices if needed e.g, a games console. For remote play you really don't want loads of devices on the same network downloading , streaming etc. at the same time as it'll cause problems so the two networks / routers actually works perfectly for my need.
Good luck with it!
Jack
So basically in our place,  only the phones and and tablets are on Wifi.  Everything else is hardwired.  But the Sky system has a handshake of over a minute sometimes and it's driving the wife crazy!  lol
Wanted to update this.  Bought a Google Nest Pro 3 and the difference is remarkable. Proper WiFi speeds through the house. No lag in handover between access point.
WiFi speeds are through the roof as well!!
Somehow despite all Sky WiFi being turned off, the Q boxes sometimes lose connection to the main Q box, which is frustrating as the main box is 'brand new'.
Not sure If that's a network issue or just poor hardware/software.
This message was authored by: Andersjt
Hi,
Sorry to gatecrash this, but have a similar issue and as a non-techie it's a nightmare to understand.
First world problem - I've got a big house. I have gigafast internet but wifi around the place is shocking.
We have the standard black sky router, 2 sky extender hubs and Sky Q boxes x 4. I've tried TPLink plug-in extenders but they are just suckng the life out of it and we can barely use 2 devices at once.
Decided to look into a mesh system - but am I reading correctly that I run this alongside the current sky set-up and don't touch that? So essentially, I have the Sky router and extenders purely for sky, and everything else would utilse the mesh?, but the mesh plugs into the Sky router?
Sorry for being thick...
Hi there,
Buy a good TP link deco mesh and wire up one of the decos to your current Sky router, and then place the other decos around your house to give you a wide coverage.
Don't play with your Sky set up - leave that as is and connected to the Sky router, then connect your other devices to the deco network.
The problem you've got is that the Sky routers are rubbish and do not give you anything like the speeds you should be getting with high speed internet. Once you've got it set up run a test from your phone on Sky router speed vs TP and you'll see what I mean.
PS, I'm not an IT expert by any stretch but this fixed all of my problems. If you do some research you'll easily find that a lot of home network problems are down to poor service provider routers.
My TP set up was about £300 but well worth the investment and will last a long time plus tonnes of customisation available to make your experience better.
Good luck!
Jack
Thank you Jack - that sounds almost straightforward - really appreciated!
No worries. Just do a bit of research on setting the initial deco up with your Sky router - make sure you connect it via a high quality Ethernet cable too. Also, make sure your deco's are in open space and not hidden in a corner or cupboard somewhere. You want them to be able to extend your signal as uninterrupted as possible, especially considering you have a big house so has more walls / ground to cover.
Let us know how you go!
This message was authored by: Pandy
Just to add as long as you keeping the Sky Router and adding a seperate network via TPLink Deco then you should be fine.
Where you do get problems is if you move away from Sky broadband and the Sky router. I have had great difficulty getting a Sky Q box to connect over WiFi to a non Sky router. It connects initially then when Q box goes into standby it won't re connect on turning on. I have to go into settings and reset the network and enter password again. Connecting the Q box via Ethernet cable to a 3rd party router works but I could not get a stable connection when using  WiFi. I've tried this with several 3rd party routers and always same problem.
