Discussion topic: 3 lights on i stead of 4
This message was authored by: Saffy1
Hi. My Internet isn't working 🤔 I only have 3 lights on instead of 4? Help plz?😥
Re: 3 lights on i stead of 4
If your ISP is Sky and your internet isn't working you need to phone Sky and report it.
If you don't report it you won't be entitled to compensation if the issue isn't resolved within 48 hours ( as the clock starts ticking the moment you report the issue).
You can call on 150 from a Sky Talk Line or Sky Mobile.
https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number. If you are in the ROI on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
@Saffy1 Is this a Sky router ? If so what lights are lit on your router ?
ple\se also privde your router stats as per the link below
https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M3125...
