Discussion topic: 2.5hz and 5hz
This message was authored by: Scottvrs
2.5hz and 5hz
Hi I'm trying to split my WiFi to 2.5hz and my smart device needs it, just trying to work out how to Splitting my WiFi to 2.5hz and 5hz not together
Re: 2.5hz and 5hz
@Scottvrs
Presumably 2.4Ghz rather than 2.5Ghz
Unfortunately unsynchronizing bands isn't possible on the white Max Hub.
Re: 2.5hz and 5hz
@Scottvrs these are the instructions for the black hubs see Split Sky WiFi bands
If you have a white hub go into the hub's advanced settings in the My Sky app and find tge control for the WiFi temporarily turn off tgec5GHz band oncecthe hub restarts connect your devices then go back in and turn the 5GHz signal on and they should stay connected.
