Discussion topic: want to move my hub but need longer cable
Message posted on 22 Apr 2021 01:16 PM
Re: want to move my hub but need longer cable
What fibre do you have superfast vdsl or ultrafast fttp with seperate ont modem ?
Message posted on 22 Apr 2021 01:38 PM
I have the super fast broadband hub SD203.
Message posted on 22 Apr 2021 01:42 PM
Sorry I do mean SR203
Message posted on 22 Apr 2021 01:43 PM
What distance between master socket and preferred router postion.
Message posted on 22 Apr 2021 01:53 PM
By the time the cable is routed around so it is tidy it will be about 9/10 meters.
Message posted on 22 Apr 2021 01:56 PM
Check argos. Currys/Dixons, amazon etc 10 metres dsl rj11 to rj11 will be no problem at that distance
Message posted on 22 Apr 2021 02:00 PM
Thanks for your help.so I don't need to work about the 4 connection leads as they will work or what you are recommended it are two connections anyway.
Just like to clarify definition of superfast as that hub is sent out as broadband boost upgrade or full fibre to the premise. What speed have you been told you will get , do you have a seperate fttp ont modem
Message posted on 22 Apr 2021 02:06 PM
Certainly not full fibre into the property. Not sure what separate fttp is sorry. Told mim will be 36 and ave 59 speed.
Message posted on 22 Apr 2021 02:09 PM
Just 10 metres of dsl rj11 to rj11 will be fine
Message posted on 22 Apr 2021 02:14 PM
Thank you for all your help 😀
Message posted on 22 Apr 2021 02:15 PM
Eg
https://www.amazon.co.uk/Metre-Internet-Broadband-Cable-Black/dp/B003AC22II#
Message posted on 21 Sep 2021 06:24 PM
My hub needs a RJ11 and a BT connector not 2 RJ11
Message posted on 21 Sep 2021 06:28 PM
Think you may need rj11 to rj11 and a microfilter
Message posted on 21 Sep 2021 06:31 PM
How many ports on your mastersocket? One for broadband and one for phone ?or just one phone socket?
