Discussion topic: want to move my hub but need longer cable
Message posted on 28 Jul 2020 05:19 PM
i need to move my hub but the cable that goes from the phone socket to the purple port on hub is too short. Please can you advised where or how i get one of thes cables, but a longer one then i have been issued with the hub
Message posted on 28 Jul 2020 05:28 PM
Re: want to move my hub but need longer cable
Hi there,
The cable is called an ADSL cable and you can buy them online from various sizes.
Sky only produce one size however and this is because longer cables are more prone to inference and this will hamper the broadband speed your hub receives.
I have been into customers homes many a time for broadband issues where a cheaply made and overly long cable was the cause of the problem. It can really be a night and day difference when it comes to broadband.
Message posted on 28 Jul 2020 06:04 PM
Thank you
Message posted on 28 Jul 2020 06:09 PM
Also sold online as 'RJ11-to-RJ11' cable.
Message posted on 29 Jul 2020 09:52 AM
Thank you
Message posted on 06 Jan 2021 01:47 PM
hi @Dan.JC
just read your recommendation/explanation and as i am needing also a longer ADSL cable for my SKY
and you advise to get a top quality one hope you be kind enough to tell this(me) clueless person the make(s) of a good top quality. have been trying to figure it out but nervous to order in case it's the wrong one.
i am also wondering now if there is a difference in quality for telefon extension leads.
kind regards
Message posted on 06 Jan 2021 01:51 PM - last edited: 06 Jan 2021 01:52 PM
@h.h. I have a 6 metre one as needed to move my modem too, there different lengths available here https://smile.amazon.co.uk/gp/product/B08BHT7N7X/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
I've not had any issues in speed or quality since using this
Message posted on 06 Jan 2021 02:18 PM
@Skull+Treaty wrote:@h.h. I have a 6 metre one as needed to move my modem too, there different lengths available here https://smile.amazon.co.uk/gp/product/B08BHT7N7X/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Personally I would go for one of these unless you are already getting a good sync speed. Link.
On my connection which is not the best, it was the difference between getting 28 Mbps with a 3m flat cable and 33 Mbps with Cat 5 one. The cheaper flat cable attenuate the high frequencies more than the more expensive Cat 5 ones.
Message posted on 11 Mar 2021 10:31 AM
Hi does it matter how many pins the extension cable has as sky has 2 and online show 4?
Message posted on 17 Apr 2021 07:31 PM
Hi.
The cable that you put link up is not available anymore on amazon. Is there any other one which is great as that one you recommended? I am not sure what I should look for. Much appreciated for you help and unswerving. Thank you.
Message posted on 17 Apr 2021 07:38 PM
Currys/Dixons do 5-10 metre dsl cables
https://www.currys.co.uk/GBUK/product-10119311-pdt.html
Message posted on 17 Apr 2021 07:41 PM
Thank you so much. 🙂
Message posted on 17 Apr 2021 07:45 PM
Just one more question is good for fiber brodband? I rather not loose the speed? The main socket/ box connection is located downstairs but WiFi dosent cover whole flat so I need to move the hub upstairs? Thank you once again.
Message posted on 17 Apr 2021 07:51 PM
It called dsl because its used for adsl copper and vdsl fibre to the cabinet. Once you go ultrafast fibre to the premise then you'll get an ethernet cable. If you are superfast thats what you'll for the time being.
Message posted on 22 Apr 2021 01:03 PM
Just wondering if some one could help, just recieved my new sky broadband hum ready for go live next week. But the cable from the hub to the phone socket is not long enough as my master socket is in the hallway and hub will need to be in the lounge. I notice that the cable that comes with the hub has two connections and longer ones I can find seem to have 4 connections. Would that work ? Or does any one know where I can get the correct longer cable.
