4
This discussion topic is read only This discussion topic has been answered Discussion topic: trouble sending emails from cctv camera through smtp any help.
This message was authored by: Deva39
I have set up all the perameters I thought was necessary . I was wondering if the firewalls were stopping it, anyone have the same problem.
This message was authored by: jayach Answer
Re: trouble sending emails from cctv camera through smtp any help.
Sometimes CCTV cameras don't allow SSL to be used so what settings are you using?
They should be :
Server - smtp.tools.sky.com or smtp.mail.yahoo.com
Port - 465
Requires SSL - Yes
Requires authentication - Yes
SPA off
Locked
They should be :
Port - 465
Requires SSL - Yes
SPA off
Avatar for Deva39
Hi thanks for the reply but have tried both those settings and still no joy.
  regards Deva39
Are you authenticating with your Sky email and password?
You may need to use a generated app password instead of your usual Sky account password.
https://www.sky.com/sky-yahoo-mail/manage-apps
This message was authored by: LeeB197266
Thank you thank you thank you!
Locked
