This discussion topic is read only Discussion topic: screen fit
This message was authored by: Roger+Wesson
screen fit
my mail no longer fits on to a single screen but now needs a movement bar at the bottom. How can I get it back to fit on one screen?
Locked
Re: screen fit
@Roger+Wesson  That varies from device to device, but it seems you have zoomed in on the device your using.
This message was authored by: jayach
Re: screen fit
If you are on a Windows PC/Laptop, try holding down the Ctrl key and using the mouse scroll wheel to size the screen to your liking.
Locked
