Discussion topic: internet connection dropping constantly
Message posted on 12 May 2021 11:59 AM
hi i new so hello anyone
I recently had a new 1tb uhd box fitted as my old one died but now i cant even watch a full youtube video or netfilx episode without Internet disconnecting .I changed from wifi to Ethernet to see if it was any help but still the same wired . my Internet is fine a 1000mbs xbox,pc,fire tv work no problems at all its so annoying box will be going out the window soon hahaha any help will be much appreciated
thanks Keith
Message posted on 12 May 2021 12:01 PM
Re: internet connection dropping constantly
thanks Keith
Hi @NEO123
Assume that you carried out a Network reset on your Q box with the Ethernet connected?
Who is your Broadband supplier?
Message posted on 12 May 2021 12:05 PM
hi thanks for your reply yeah i did somethink a little strange is it says its connected to sky9*** network whitch isnt mine mine isnt called that im with youfiber (new company doing 1gb fttp )
thanks
Message posted on 12 May 2021 12:11 PM
thanks
Hi @NEO123
Something isn't a Network reset. What exactly did you try?
The Network SSID shown in the Q box can be ignored as it could refer to the Q box Mesh ID.
Message posted on 12 May 2021 12:13 PM
ah ok yeah i did the reset i meant i noticed something strange i.e the network name
Message posted on 12 May 2021 12:16 PM
Message posted on 12 May 2021 12:26 PM
hi it said network look ok are you sure you want to reset i clicked confirm it reset i then click internet from another provide then it connected
thanks
Message posted on 12 May 2021 12:30 PM
Message posted on 12 May 2021 12:32 PM
yeah i did the option for "from another provider"
thanks
Message posted on 12 May 2021 12:56 PM
Hi NEO123
As oldfella mentioned above you need to select "Connect using a wired connection" then don't press the wps button.
If you select "Connect to wifi from another provider" this will connect to your broadband over wifi even if you have ethernet cable connected.
Hope this helps.
Tom
Message posted on 12 May 2021 12:58 PM
i did do that
thanks
