The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
05 Nov 2021 05:26 PM
Our wifi signal was poor on the top floor of our house and such things as trying to watch Netflix would often buffer.
We got a Sky Booster box today and set it up before which I did a wifi signal speed test. After the booster was set up and working, I did another wifi speed test and the signal is now worse than before!
Any ideas how this can be the case when it's supposed to boost our wifi speed?
05 Nov 2021 05:28 PM
Posted by a Superuser, not a Sky employee. Find out moreWhere did you setup the booster in relation to the router & the place thats having issues with signal?
05 Nov 2021 05:36 PM
I initially the first floor (router is on the ground floor). Then on the 3rd floor which is where the wifi signal problem originally was.
05 Nov 2021 05:38 PM
Posted by a Superuser, not a Sky employee. Find out moreThe booster needs to be around midway between the hub and signal problem area. Once its in that location make sure all lights are lit on the booster, then on your phone switch WiFi off then back on and see if that works
05 Nov 2021 05:47 PM
Ok I've done what you suggested and run another speed check upon the top floor and it's now even weaker!
05 Nov 2021 06:02 PM
Posted by a Superuser, not a Sky employee. Find out moreSpeed or signal check? A booster wont always improve your speed, its designed to provide coverage
05 Nov 2021 06:28 PM
A speed check. It's nearly halved the speed since setting up the booster. Internet us slow to open pages, images, Netflix buffering etc.
05 Nov 2021 11:43 PM
Yes that is quite possible. Did you get the booster for speed or range. Boosters often come at a sacrifice of speed for more coverage.
06 Nov 2021 09:29 AM
As I've described before, the wifi signal and download speed was slow on the top floor. Internet was slow when browsing ie websites slow at opening etc and streaming such ad Netflix buffers. A Sky technician told me that we would need a booster to improve the wifi on the top floor. Its now worse with the booster in place.
06 Nov 2021 12:59 PM
Posted by a Superuser, not a Sky employee. Find out moreThe signal strength should improve but speed may well be the same or less. If the signal strength isnt improving then there must be an issue with the setup
