This discussion topic is read only Discussion topic: WiFi problem
This message was authored by: Apple+Watch+help
WiFi problem
Hi my hub lights are all green but I am having problems with my WiFi it's is running slow and some of my devices are not connecting to the hub this has happened over night it was all fine yesterday
Locked
This message was authored by: Skull+Treaty
Re: WiFi problem
@Apple+Watch+help
Can you run the Broadband Test from the MySky App or using this link:
https://www.sky.com/pages/sky-com/test-your-broadband
Then, please post your router stats, this can be done following the information in the link below.
https://community.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M1014
This message was authored by: JPR007
Re: WiFi problem
@Apple+Watch+help Sounds like the hub has done an overnight firmware update. Shut it down for 30 mins, then fire it back up and see what happens.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Locked
