Discussion topic: What ki d of cable is needed for satellite
This message was authored by scottg75 This message was authored by: scottg75
I left sky tv and returned my q box and all cables. I have joined back again and received a new q box but have no satalite cable that goes in the back of the box and into the airel on the wall. What kind of cable do I need to purchase?
Locked
Re: What ki d of cable is needed for satellite
Hi @scottg75
Assume you still have the Satellite dish with Q LNB.
Best satellite cables are WF 100
Twin or two singles are required
@scottg75
Hopefully the 'airel on the wall' is actually a dish connection (typically a pair of connections, unless it's a communal dish)
You need either one or two coaxial cable satellite leads with f-plug connectors (note 'aerial' leads for Freeview are different and not suitable: they don't have screw-thread fittings)
This message was authored by Raider999 This message was authored by: Raider999
@scottg75 you shouldn't have to purchase anything, sky should supply everything you need free of charge.
This message was authored by NickNewark This message was authored by: NickNewark
Don't think they would supply the cable for satellite connection as they'd assume that was still there. Sounds like the customer has a satellite wall point connection, And not the cable feeding directly from the dish.
This message was authored by Mark39 This message was authored by: Mark39
No, they wouldn't supply flyleads, you're right,
This message was authored by Laing1 This message was authored by: Laing1
I think @TimmyBGood has probably hit the nail on the head and that this is a communual dish and the lead from the wall socket to the box has been sent back when they returned all the previous equipment maybe if this is a communual dish there might be spare leads kicking about if the op asks who ever is responsible for the communual system failing that then a short cablke from a well know online store may suffice
scottg75
It's a communal dish I have. Will a f cable do from wilkos?
This message was authored by bob1234 This message was authored by: bob1234
@scottg75It should work so long as you previously had Q and not +HD.
Also the LNB in the Q box needs to be set to SCR otherwise it will not work with one cable. You need to go into the engineers menu to change this.
@scottg75 as @bob1234 says yes also
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
This message was authored by Godfrey This message was authored by: Godfrey
@scottg75 ... your new Sky Q box will arrive configured to use a Wideband LNB by default, as you are going to connect it to a communal Integrated Reception System you will need to enter the engineer's 'hidden' menu in order to change that receiver's LNB type from Wideband to SCR.
So, press the HOME button on your remote control
If you scroll down to SETTINGS (but do not then press SELECT)
Then quickly press 0,0,1,SELECT
This should then show the LNB type
If it is showing Wideband, change it to SCR
Switch your Sky Q receiver OFF with the remote
Remove the mains power from your receiver for 30 seconds and restart your Sky Q receiver, it should now be configured to use a Single Cable Router feed from your communal IRS dSCR / dCSS distribution multiswitch.
Godfrey       ( I obviously type too slowly! )
That's a very good point, and a distinct potential flaw in the Sky policy of not having engineer attendance for reinstallation in an address where Q has been previously working: communal systems really need to be flagged for this.
This message was authored by lgladdy This message was authored by: lgladdy
Weirdly, i had a communal Sky Q re-install this week, but it wasn't a self install - that wasn't offered at all during checkout, just a full engineer setup.
@lgladdy
I think that's much more appropriate: subscribers shouldn't really have to be directed to a 'hidden' menu ; )
Locked
