Discussion topic: Sky Q being installed tomorrow
This message was authored by WorriednewtoQ This message was authored by: WorriednewtoQ
Hi There, I'm due to have Q fitted tomorrow. I tried to get this a few years back but the installer was very unhelpful. Our sky dish is out the back and the main box will be at the front of the house. I may sound really thick but what does that entail to get it fitted.
Locked
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Sky Q being installed tomorrow
@WorriednewtoQ Our dish is at the back. Sky Q in front room. Cable runs through the wall behind the box, along the outside side wall and to the dish. Presumably, as long as you don't live in a terraced house it will be similar.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
WorriednewtoQ
@Daniel0210 thank you so much for your reply, that's put my mind at ease. I didn't want them to say it can't be done.
@WorriednewtoQ
By definition a satellite dish has to point (very precisely) at the satellite cluster delivering the signal: this does tend to limit where they can be placed on the property. As @Daniel0210 indicates, Sky installers are very used to such situations, but there does need to be access for an external cable run along a wall because they'll typically no longer casually throw it over the roof as they used to ; )
@WorriednewtoQ You say your dish is currently at the rear of the property so presumably you have Sky+. Is the Q box going in the same place?
This message was authored by Laing1 This message was authored by: Laing1
@WorriednewtoQ if you have a dish do you still have cable attached to the dish running to the room you want Sky Q in ?
if the cables are already there then they will re-use the cables if you have removed the cables or have changed where your box is going from where the cables used to be then as per the other answers
Locked
