This discussion topic is read only Discussion topic: What do i need for sky Q
This message was authored by: APotter73
What do i need to allow Sky Q to work? I assume an aerial, a TV and wifi - polus the SKy Q box. ANything else?
Locked
This message was authored by: ozsat
Re: What do i need for sky Q
Sky provide you with a working SkyQ system with the box and dish - you provide the Internet and tv.
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
@APotter73 The obvious thing you've missed from that list is a Satellite Dish but as @ozsat says, Sky will provide that along with the Sky Q box.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
This message was authored by: bob1234
@APotter73When you say aerial you do not need the terestrial type that is used for feeview  Q uses a dish instead which Sky provide. If you are changing from an earlier version of Sky HD etc the same dish can be used.
If you are in a block of flats etc there will probably be a communal dish already and you will not need one.
Locked
