Discussion topic: Watching sky Q on VR?
Message posted on 17 Feb 2021 03:24 PM
- Hi, I have an Oculus quest 2 and wish to watch my sky q content on the equivalent of a 100 inch TV! (same as I do Netflix or amazon prime!)
- But there is NO sky go app for VR, Aaaanndd the SKY VR APP is ONLY for sports!!
- I have tried running sky go on my pc, and using virtual desktop to stream to my headset, but just get a black screen (BLOCKED!!)
- CAN SOMEONE HAVE A WORD WITH SKY TO ADD A VR SKY GO APP!!????
Message posted on 15 Jul 2021 10:16 PM
Re: Watching sky Q on VR?
Open it in the desktop app also look into big screen on steamvr
Message posted on 16 Jul 2021 07:58 AM
Tried it, you CAN'T stream the app, it won't let you, all you get is a black screen and the sound! 😭
Message posted on 16 Jul 2021 09:52 AM
Depending on the hardware of your computer there is a Android emulator called Nox player install it when installed go to its settings and look for network in there it will say bridge and install driver do this reboot Nox then open play store download the sky go app and you can watch it from there again on desktop or big screen or apps like that
Message posted on 17 Jul 2021 07:03 PM
Thanks for that info, unfortunately I've left sky for virgin, but might still use that info!
Message posted on 19 Jul 2021 10:57 PM
This would be because of DRM (Digital Rights Management) used on Sky Q on PC which prevents screen capture..
